Vertical exhaust on a Briggs.
68 Mag
04-18-2002 13:13:05
I have a 12 horse Briggs and Stratton I/C engine. The exhaust appears to be a 1" diameter, but I've yet to check. My question is- Can I run a piece of threaded, galvanized steel pipe from the exhaust on the block out about 6-8 inches, then put a 90* elbow, then the vertical 'exhaust stack' from a Farmall Cub? I've heard of people doing this, but I dont want to damage anything.
Thanks,
68 Mag
Brad Wies
04-18-2002 17:47:49
 Re: Vertical exhaust on a Briggs. in reply to 68 Mag, 04-18-2002 13:13:05
third party image
Hello, it can be done, I did this on my '59 Simplicity 700 and it came out great, click the link to go to my "how-to" article on simple tractors. Good luck,-Brad Wies
bob ny
04-18-2002 16:34:07
i woldn't use a 90% ell a pair of 45% is less resiatance
lucas
04-18-2002 14:38:56
you can do it and it should run fine but you may need to support the extension so that all the weight and vibration are not on the block threads alone causing a threads failure their .by making a support bracket and clamping to it..i like ex stacks,cap it so it dont rain in it,lucas
68 Mag
04-18-2002 14:41:09
 Re: Re: Vertical exhaust on a Briggs. in reply to lucas, 04-18-2002 14:38:56
Thanks. I plane to support it with a welded brackect off the mower frame...and put on a cap...
