Changing a tire
Jon
04-20-2002 19:26:01
I need to change some tires that are on 8" rims. What is the best way to do this? TIA
K-Mo
04-21-2002 17:16:28
 Re: changing a tire in reply to Jon, 04-20-2002 19:26:01
Jon,
I bought a Mini Tire Changer (No. 34552) from Harbor Freight. It's about $30. I attached it to a piece of 2" square tubing and stick it into the hitch on my pickup truck when I want to use it. It has worked surprisingly well.
A little experience helps. 1)When prying the the bead over the rim make sure the rest of that bead is on the small diameter of the rim. 2) Use lubricant. I use Murphy's Oil Soap.
Good Luck
K-Mo
Jon
04-21-2002 18:09:24
 Re: Re: changing a tire in reply to K-Mo, 04-21-2002 17:16:28
Thanks for the tip. I just went and looked at it and it looks just like a big tire changer except it is smaller. I just ordered one.
