Cub 2518 or JD GT225?
Tim
04-25-2002 11:27:17
Any opinions on which is the best bang for the buck? 1.5 - 2 acres, moderately hilly..would also like to use this machine to pull gravel up my 1ooyd. long drive way...
greg
11-19-2003 09:23:09
 Re: Cub 2518 or JD GT225? in reply to Tim, 04-25-2002 11:27:17
I have a 2518 cub used it to pull tree stumps out after huricane Isabel. Also I have a hydro tiller I till up about 1/2 acre. In my opinion it a much heavier built machine than the JD 225. Shaft drive 150lb. cast iron hydro transmission servicebal filter the trany holds 6qts. of fluid. I'm not saying the 225 is not a good machine, the cub is just heavier built for my needs. GREG
Tony
05-14-2004 14:20:03
 Re: Re: Cub 2518 or JD GT225? in reply to greg, 11-19-2003 09:23:09
I have a Johne Deere GT 225 Lawn tractor. I was mowing yesterday when it just quit altogether. After checking all the necessary components of combustion I discovered a No Fuel situation. Not out of gas, I started a search of the fuel system and all I could find was an electrical switch inside the carburator that looks as though it is a normally closed swicth. I checked for voltage on it and there wasn't any. Does anyone know about this particular situation and where does the wire go? If it goes to the sensor board,I just bought I would really like to know...
