Briggs won't run under load
Ken
04-26-2002 19:04:10
I have a 18 h.p. v-twin Briggs that won't run under a load. It suddenly did this the other day, was running fine , then started choking. I believe I have cleaned the carb as well as I can. New plugs and new fuel filter seemed to improve it a little but not much. Carb blows A LOT of fuel when running. I imagine something is plugged or not adjusted right, I just don't know what. One other thing. There is what appears to be a fuel pump on the front of the carb. It has a bladder and several springs in it. The bladder would be a wear part I would think. Is there a rebiuld kit for this? Any suggestions would be appreciated.
Rich
04-27-2002 18:33:35
 Re: Briggs won't run under load in reply to Ken, 04-26-2002 19:04:10
Did you try fresh gas.
