Case 222 Compact Tractor
Robert Kalb
08-12-1998 19:39:23
I have a 1976 Case 222 tractor I would like to sell. Could be rebuilt or used for parts. Would consider breaking down and selling parts.
Dave
06-04-2002 15:40:46
 Re: Hydro fluid in reply to Al, 06-04-2002 04:42:28
Al - You should use John Deere Lo Viscosity HyGard Hydraulic Fluid in your unit. Type F is an acceptable alternative, if you can find it. Dexron IS NOT A GOOD CHOICE for your hydro unit. You should also use the filter available from John Deere. Their filters are not over-priced. Too restrictive of a filter will cause flow problems and the hydro unit will be less responsive and can lead to overheating. - Dave
