DEERE 430 DIESAL
John Kauzlaric
04-28-2002 10:12:06
Has anyone used some sort of disc or plow with their 430? I`m wondering if 20hp will do the trick.
Terry Weivoda
04-29-2002 03:59:34
 Re: DEERE 430 DIESAL in reply to John Kauzlaric, 04-28-2002 10:12:06
John, I had a 430 with bar tires and rear wheel weights. I used the JD 12" plow on the three point hitch with no problem. In low range even in sod it worked fine. There were a few times in heavy clay the 430 just put out a little black smoke but kept on pulling.
Brandon
04-28-2002 17:49:31
More than enough with the right equipment!
check out www.brinly.com
