Cub Cadet 72 funny starting.
Ludwig
04-29-2002 06:45:16
Hi all.
A friend of mine recently bought a cub cadet model 72. It runs good and seems real powerful, but its funny when it starts.
When you first hit the key nothing happens, then you figure "oh man, dead battery." But if you then hit the key again it'll crank. Slow at first but it'll build up steam. If you let off the key and go back on you keep the speed you had before, its like just cranking makes it crank better.
So then it'll start to fire, once, twice, a couple more times, and then start and run good.
I think the hardstart is due to needing a tuneup, but the starter's got me cornfused. Should we take it (the starter) to a shop and have it looked at? Is this a common problem?
Lou
04-29-2002 08:08:38
 Re: Cub Cadet 72 funny starting. in reply to Ludwig, 04-29-2002 06:45:16
Sounds like a bad battery, but could be the solenoid. Check and clean the battery, starter, and solenoid terminals. Try jumper cables.
Jeremy
04-30-2002 00:12:23
 Re: Re: Cub Cadet 72 funny starting. in reply to Lou, 04-29-2002 08:08:38
I'm with Lou on this one. Take the battery to have it load tested, and make sure that all of the terminals on all the cables are clean and are tightly connected.
Marvin
06-09-2003 03:40:04
 Re: Re: Re: Cub Cadet 72 funny starting. in reply to Jeremy, 04-30-2002 00:12:23
could be a combo problem. partly too thick of an oil and dirty battery leads
