Cub cadet 1606
Ron
05-02-2002 03:41:24
Just got a Cub Cadet 1606 & haven't had much chance to check it out yet. Problem; tractor will not move. Clutch is ok, drive shaft is turning into the gearbox, the gear shift is working & I can tell that it is engaging the gears. Any ideas on the fix? Looks like I need to start by driving out the roll pins & sliding the collar back where it goes into the gearbox, then remove the 4 bolts holding the gearbox to the transmission. Am I on the right track--don't have a parts breakdown of the gearbox. thanks
Ron
05-02-2002 20:27:17
 Re: cub cadet 1606 in reply to Ron, 05-02-2002 03:41:24
Problem fixed, sheared roll pin on a gear in the gear reduction case.
