Cub 126 mower belt
Denny
05-03-2002 19:07:04
I've noticed that the belt seems loose on my 48" mower deck.It cuts ok but makes a lot of noise from the belt deflection,which I measured at 3" side to side by looking at the scuff marks the belt makes on the deck.Previous owner said the tractor hadn't been run for 2 years.Pulleys seem ok and the idler pulley seems to work good.Do I just need to try a new belt or is there some other adjustment(s) I need to know about?
Denny
05-11-2002 06:42:42
 Re: Cub 126 mower belt in reply to Denny, 05-03-2002 19:07:04
Thanks fellas for the suggestions and part # .Exactly the info I was looking for!
Denny
mark in florida
05-09-2002 18:09:49
cub cadet part number for DECK BELT
754-3053
mark
mark in florida
05-09-2002 18:11:01
 Re: Re: Cub 126 mower belt in reply to mark in florida, 05-09-2002 18:09:49
hopefully thats a 48" model 317 mower deck
Glenn(WV)
05-03-2002 22:57:21
Are you sure it's the correct belt?
Denny
05-11-2002 06:37:49
 Re: Re: Cub 126 mower belt in reply to Glenn(WV), 05-03-2002 22:57:21
Not sure,Glenn.No numbers visible on the belt.Gonna go ahead and replace it with a new I.H. belt since I don't know how long it's been on there.Thanks
Denny
Don Cress
05-04-2002 05:07:19
I had a 1969 -126 for about 25 years ...My grandfauther was a "IH" dealer...I found that I had to use "IH" belts..They are just enough different that others like GATES would not holdup.....I learned that on the small gen,/srarter belt.....it ate the GATES belt in just a short time....The first thing you need to do is remove the deck belt and check the side to side and end play in each of the three pulley bearing sets...you do this by turning the deck over and see if there is any slop inthe bearing adjustment or maybe they need to be replaced....do the simple things first...make sure the blades are balanced..My guess is thats the problem!
