Lawn Tractor dies for no apperant reason.
AL
05-08-2002 11:34:42
I have an old ~1978 Montomery Ward lawn tractor with a B&S 8hp engine. It starts and runs just fine in neutral. When I start moving (either in 1st or 2nd of iys 3 speeds) it will choke out and die in only a few short minutes.
Ideas???
I replaced the plug and checked the gas.
Mark in florida
05-08-2002 19:32:57
 Re: Lawn Tractor dies for no apperant reason. in reply to AL, 05-08-2002 11:34:42
1 make sure governor arm moves freely
2 if air vane gonernor then remove flywheel cover and clean debris
if you have any more questions
please dont hessitate to e-mail me
Mark farmequipmentetc@yahoo.com
Art
05-08-2002 15:03:04
Hi Al, I have a 72 model of the MW. I would also check the carb. clean out the main jet. A little bit of dirt clogging one, could allow it to run but restrict it enough to prevent a load. Sometimes if you let out on the jetscrew a little the debris will run through, on its own....Good luck Art
