Cub Cadet Idle Problem
Steve U.S. Allo
05-09-2002 14:50:16
I have a Cub with a 12 horse Onan. It surges when you try to idle it down and dies before it will idle completely down. Dirt in the carb? I don't know and was hoping someone could shed some light. Any comments would be appreciated.
Steve
Steve U.S. Alloys
05-10-2002 05:27:44
 Re: Cub Cadet Idle Problem in reply to Steve U.S. Alloys, 05-09-2002 14:50:16
Your replies are very much appreciated. Guess I'll start with the simplest solutions first and work from there.
Thank you.
Jim S.
05-10-2002 04:34:00
In no particular order:
1.) blocked gas cap vent
2.) clogged sediment bowl/sediment bowl screen
3.) fuel line clog
4.) improper float adjustment
5.) idle screw setting not correct (too lean)
6.) dirty carb...needs soaked in carb cleaner/rebuilt
7.) clogged air filter
Mark in florida
05-09-2002 17:03:26
are you sure its a onan motor or kohler. at any rate try spraying carb cleaner all over the carb to clean all the grime off it. the idle air bleeds are probably clogged
