Cub Cader Wide Frame
Narrow Frame
Lester Lawson
05-10-2002 08:08:15
I own a CC 102 and a 1000.I read about a narrow frame CC and a Wide Frame CC. Would one of you be so kind to explain the difference. Where does the wide frame models start and stop and also the narrow frames.
Thank's
Les in SC
Paul
11-22-2002 23:33:03
 Re: Cub Cader Wide Frame - Narrow Frame in reply to Lester Lawson, 05-10-2002 08:08:15
I also was wondering what exactly is the difference betwen a narrow and a wide frame CC. I have a 1200, and dont know if its a narrow or wide. I was offered a complete snow blade attachment for it, but the seller referred to it as fitting a narrow frame quick attach. Will this fit my 1200 CC? Paul
A.Gonya
05-12-2002 11:47:49
Norrow frame Cubs ended with the 6/7 series 106,107,126,127,147,Tractors. In August of 71 IH introduced the 8/9 series wide frames. (108,109..ect )As far as the Wide frames being made heavier I personaly disagree, I am fairly shure they were made from the same gauge of steel. A Narrow frame Cub Cadet Frame is virtually indestructible through normal use. At least as tuff as an early wide frames. IH made the change because of engine flywheels I believe, Fitting a 16hp K series in a Narrow frame is very difficult They had to modify the 147 frame just to take the 14hp engine (Narrow frames forever)
Andrew
05-10-2002 09:19:44
I'm no expert so I can't remember when they started using the wide frame, someone here would know, but from the stearing colum fwd it is wider o nthe wide frames than the narrow frames and the wide frames have a more robust frame. your 102 would be a narrow frame and you 1000 would be a wideframe.
Andrew
Les
05-11-2002 12:20:14
 Re: Re: Cub Cader Wide Frame - Narrow Frame in reply to Andrew, 05-10-2002 09:19:44
Andrew: Thanks Les
