110 motor problem
Larry
05-11-2002 13:54:53
I recently bought a 1967 110 in all original condition. It starts and runs great but when you start it, it "puffs" out the dipstick about an inch. If you push back in it seems to stay till the next time it starts. Does not seem to smoke or use any oil. What gives with the belching dipstick?
Mark Meeks
05-12-2002 05:51:32
 Re: 110 motor problem in reply to Larry, 05-11-2002 13:54:53
Sounds like the crankcase vent is stopped up. Or you may have a little blow by gas caused by worn rings. Good luck: Mark
Larry
05-13-2002 13:07:46
 Re: Re: 110 motor problem in reply to Mark Meeks, 05-12-2002 05:51:32
Thanks for responding back. I just got it out this past weekend. I'll do a little checking. It does not seem to smoke or use oil. I'll look at the books, the crankcase breather is under the carb. isn't it? May be a silly question, but always better to ask than screw up too bad.
Mark
05-14-2002 06:22:17
 Re: Re: Re: 110 motor problem in reply to Larry, 05-13-2002 13:07:46
Yes the crank case vent is connected to the carb. Which motor do you have? Mark
Larry
05-14-2002 06:34:33
 Re: Re: Re: Re: 110 motor problem in reply to Mark, 05-14-2002 06:22:17
It is the 181 Kohler. 8HP in a 1967 110. Thanks for your help.
