Electronic Modules
Donald Holden
05-12-2002 08:49:48
Can anyone tell me if an electic module that is designed to replace the points/condensor ignition will work on an single cylinder 16 HP Cast Iron Briggs & Stratton approximately 30 years old.
Thanks for your comments!
Don
Mark
05-12-2002 15:26:44
 Re: Electronic Modules in reply to Donald Holden, 05-12-2002 08:49:48
It sould bolt right up. They make a converter for your coil for about $15.00 if your coil is ok. If not remove the coil and bolt the module on. Good luck: Mark
lucas
05-12-2002 09:16:47
briggs will have to reverse polarty on your flywheel. your dealer can send it in for you and then you can successfully install the electronic ignition,,lucas
