6-HP Sears/Craftsman Roto-Spader (Circa 1970's?)
Kevin
05-15-2002 09:27:37
Runs fine. Sears/Craftsman (likely B&S) engine.
Need clutch lining and lining retaining ring. Vertical shaft drive with tine worm. Easily accessible by pulling engine from frame (10 mins). Reverse belt would also be nice, but not essential. Possibly/likely an Atlas clutch but can't find company info.
Model No. 785.295060
Sears no longer has parts. Other internet parts houses have no parts. Probably need junker for parts.
Any help out there?
Thanks,
/s/ Kevin
Cody, Wyoming
lucas
05-15-2002 11:31:59
 Re: 6-HP Sears/Craftsman Roto-Spader (Circa 1970's?) in reply to Kevin, 05-15-2002 09:27:37
if you still have some lining present you can add a washer on the ned of the crank to shim the two clutch parts closer together..i had a new lining glued on at a clutch rebuild place once..lucas
Tony Butler
04-16-2005 19:37:21
 Re: Re: 6-HP Sears/Craftsman Roto-Spader (Circa 19 in reply to lucas, 05-15-2002 11:31:59
I have a Sears 4 hp Roto-spader #785.298340. I need parts too or I"ll sell it. I can"t find any info on it and would greatly appreciate it if someone had a picture or manual o0f this or a similar model so I can get it going. It runs good but is missing a few parts.
I"m in San Diego
tony 619-405-4606
tonybutler@cox.net
Kevin
05-15-2002 14:12:50
 Re: Re: 6-HP Sears/Craftsman Roto-Spader (Circa 1970's?) in reply to lucas, 05-15-2002 11:31:59
Lucas,
Thanks. Gluing is an option with some of the newer epoxies available. I do have two large pieces of lining left. I'll try that as a last resort.
Any idea if any other models of tillers or driven equipment use conically shaped clutches with pads or linings (lining is about 1" tall; 1/8-3/16" thick; nearly full circle)?
/s/ Kevin
