1872 Cub Cadet-Hyrdo
JMC
05-16-2002 05:40:22
This is my neighbors mower and the hydro works good, but doesnt maintain the proper speed on grades. Speeds up downhill, slows down uphill and pretty sure it shouldnt do that. Any simple solutions without tearing in to it too deep?
Glen01
03-30-2005 11:34:44
 Re: 1872 Cub Cadet-Hyrdo in reply to JMC, 05-16-2002 05:40:22
I need an electrical wiring diagram for this tractor. The electric clutch will not release when you shut the mower desk off. Does any one have any suggestions on what the problem may be. If I have a wiring diagram I can trace the wires, I beleive it is a bare wire somewhere and I am getting an electrical feedback.
fred
06-21-2004 20:26:30
I recently bought a 1872 Cub Cadet-Hydro. I am having trouble with the speed, when I push the speed control lever foward or in reverse the tractor begins to slowly creep then suddenly speeds up. I have made several adjustments nothing seems to help. Any help would be greatly appreciated.
Jim S.
05-17-2002 05:10:51
The slot in the trunnion shaft is worn, or the governor springs in that slot are worn out, or both. They are both external fixes. No need to go inside the hydro.
JMC
05-17-2002 05:59:15
 Re: Re: 1872 Cub Cadet-Hyrdo in reply to Jim S., 05-17-2002 05:10:51
thanks Jim. Have to take a look at it this weekend.
