Panzer charging problem
ADKDOOD
05-16-2002 06:57:11
Hi I have a Panzer T758E which works great except that the battery doen not seem to charge, all connections look OK I mostly have to jump start it off my truck. The engine is a Kohler K181. It has an ammeter which always reads in the negative when the machine is running. Any ideas? The starter motor acts as the generator, would this put out DC? could the wires be reversed somewhere causing it to try to charge it with the wrong polarity? How can I test it?
Thanks for any help
KB
05-17-2002 16:54:34
 Re: Panzer charging problem in reply to ADKDOOD, 05-16-2002 06:57:11
Yes the generator should put out DC (about 13+VDC for a 12 volt system. There are several things to check for. First look to make sure all the connections are tight and not corroded. You should be able to take the starter/generator to a automotive electric shop and have them bench test it. I have seen these have a simple problem such as the brushes inside wore out to have a bearing go bad and the rotor scuff the field windings. The other thing that plays a part in this is a little box usually about 3 or 4 inches square which is the voltage regulator which controls the output of the generator. If the voltage regulator goes bad it doesn't "turn the generator on".
Good luck. If you need more information email me.
