Briggs and stratton wiring diagram
Dave
05-18-2002 17:31:55
I've gotten some help off of this board and I need more. I am trying to correct the wiring on my brothers wheelhorse. It had a vertical 8hp b/s engine on it with a hole in the crankcase. He replaced the B/S engine with a similar 8hp vertical. BUT. The magneto has two wires coming out from under the flywheel shroud. Their connectorized and extend as a white and red wire about 48" long. He has connected the main wires to the frame and starter so it starts but it can't charge the battery. I need a little info on a B/S wiring or a wheelhorse wiring so I can connect these wires across the key switch or a diode. I checked with a B/S dealer for a rectified connector but he couldn't help me. Any ideas? Thanks In Advance, we appreciate all responses. Dave
Dave
05-18-2002 18:41:45
 Re: briggs and stratton wiring diagram in reply to Dave, 05-18-2002 17:31:55
I'd be happy if I had the old wiring. All I've got is a newer engine installed and two hanging wires.
Mikeh(MD)
05-18-2002 18:30:50
If you still have the old engine, remove the old altinator from under the flywheel and change it out on the new one.
Mike
