Cub Cadet 2135 Wiring Diagram
butch
05-25-2002 11:05:28
In need of a wiring diagram for a Cub Cadet 2135. I want to defeat the blade stop feature while in reverse.
Dwight E
04-08-2003 21:20:07
 Re: Cub Cadet 2135 Wiring Diagram in reply to butch, 05-25-2002 11:05:28
Butch,
I was able to get mine to mow in reverse by disabling the lever that mashes a cut off switch when you press reverse. If you take the deck off and lay under the mower you will see that there is a lever that goes up when you mash the reverse pedal. The lever is on the left side of the mower and toward the front of the moving parts that make it go in reverse. I removed the small spring that applies pressure to the switch and the lever wasn't able to mash the button to cut off the deck. I should tell you that they designed that feature with safety in mind so don't hold me liable if something happens. Good Luck!
