446 Case Deck Bearings
SEAMO
05-28-2002 12:39:08
MY 446 Case deck Brgs are making a noise. Can both the top and bottom brg's be replaced if so does anybody have part # of brg's? Serial # of tractor is J-803531384 . Is the muffler available from anyone other than Ingersol? Any help would be appreciated.I am try to get some parts together before I tear it down. Thanks a lot. Earl
Dan DeMattia
05-30-2002 13:02:13
 Re: 446 Case Deck Bearings in reply to SEAMO, 05-28-2002 12:39:08
Check to make sure the pulley on top of blade spindle is not loose and possibly has a bad woodruf key
Jim
05-28-2002 19:28:15
Yes both bearings can be replaced, just rebuilt a deck on a 220. The deck itself should have a model number on the outside edge. That is the model number you will need to get parts. Ingersoll has the parts seperate or will sell the whole spindle. Bearings through Ingersoll on mine were $8 each. As cheap as going through the parts store and matching bearing numbers. Good Luck, Jim
SEAMO
05-29-2002 09:37:53
 Re: Re: 446 Case Deck Bearings in reply to Jim, 05-28-2002 19:28:15
Thank you Jim, I think I will check to see if they have the parts. Earl
