Briggs Sputters Misses after it Warms Up
Dan
05-28-2002 13:25:58
Still having trouble with the 10 hp Briggs in my old Simplicity 3110. Rebuilt the carb- went thru it twice rechecking everything. Begins to sputter and miss after it warms up- about 10 to 15 minutes. Will not adjust out with the high speed and idle adjustments- I think it’s something beyond the carb. I’ve installed a new plug and new coil (electronic ignition) - not much more I can do there. Flywheel key in good shape. I plan next to pull the head, check the valves, seats, springs, etc. Any other suggestions before I dig deeper? Thanks for any input.
Jim
06-10-2002 18:13:42
 Re: Briggs Sputters Misses after it Warms Up in reply to Dan , 05-28-2002 13:25:58
Sounds like it could be valves not seating all the way!They may have stretched a little from heat.Check clearance,I don't know what they're supposed to be ,but that may be your prob.You may have to grind a little off stem.
