Hydro fluid
Al
06-04-2002 04:42:28
I havea jd 300.I have read posts recomending type f trany fluid for this unit.All I see on store shelves is atf+3 and mercon/dextron111.Are ether of these correct or should I make the journey to the jd dealer?
Thanks
Al
Dave
06-04-2002 15:40:46
 Re: Hydro fluid in reply to Al, 06-04-2002 04:42:28
Al - You should use John Deere Lo Viscosity HyGard Hydraulic Fluid in your unit. Type F is an acceptable alternative, if you can find it. Dexron IS NOT A GOOD CHOICE for your hydro unit. You should also use the filter available from John Deere. Their filters are not over-priced. Too restrictive of a filter will cause flow problems and the hydro unit will be less responsive and can lead to overheating. - Dave
Al
06-04-2002 15:54:35
 Re: Re: Hydro fluid in reply to Dave, 06-04-2002 15:40:46
Price is not the problem,since I can't get a filter near home I will take the time to drive to a jd dealer and get the right stuff.Thanks to all that replied.
Al
lucas
06-04-2002 05:18:41
the mercon dextron will work fine. the only difference in it from type f is it has a higher heat tolerance. we have used the dextron in our fleet for all automatic transmisions with great success,,,lucas
Al
06-04-2002 06:09:35
 Re: Re: Hydro fluid in reply to lucas, 06-04-2002 05:18:41
Thanks Lucas,I should have also asked about filters.The 20 micron I use on the hydralics of my farm tractor looks like it would fit,would it be accectable(a new one,of coarse)?
Al
lucas
06-04-2002 09:02:09
 Re: Re: Re: Hydro fluid in reply to Al, 06-04-2002 06:09:35
what we do is try to use an exact cross or the same micron as reccomended by the manufacturer. luas
Tony
06-04-2002 13:01:05
 Re: Re: Re: Re: Hydro fluid in reply to lucas , 06-04-2002 09:02:09
I have a Jacobsen Super Chief 10 hp kohler. I can't seem to find anyone who can tell me what type of hydro-static transmission fluid to use since the manual calls for either of two types that no one has and can't seem to cross-reference the numbers to anything more current.
Does anyone know what type of fluid and where to buy some along with a filter?
The type of fluid originally called for is:
Sunray DX Altran 100 Type fluid No. 30216, or
International Harvester All-Weather Hy-Tran Fluid, No. 372 705 R4, or exact equivalent.
Any info anyone can provide me would be most helpful. thanks, tk
