Case 220 shift lever.
Scott Nelson
06-05-2002 20:14:19
I have a Case 220 that shifts very rough from forward to reverse. When I depress the spring in the shaft, it shifts smooth. I need to replace the nylon bearing surface that the finger on the lever rides on. Anyone know where I can find this part?
Max
06-05-2002 22:21:46
 Re: Case 220 shift lever. in reply to Scott Nelson, 06-05-2002 20:14:19
Have you tried a bearing house for the nylon bearing? If you know the size, match it up with an IGUS bushing, I beleive they have a website.
scott nelson
06-08-2002 07:17:50
 Re: Re: Case 220 shift lever. in reply to Max, 06-05-2002 22:21:46
I believe that this will be a factory part. The 'bearing' i am talking about is really just a piece of nylon with a notch cut into it to center the shift lever in neutral. I am wondering where I could get the part.
Max
06-08-2002 20:52:29
 Re: Re: Re: Case 220 shift lever. in reply to scott nelson, 06-08-2002 07:17:50
Ingersoll dealer
