Brigg 11 hp crankcase gasket re-assembly
scott
06-06-2002 20:18:26
I had a severe crankcase gasket leak, so I broke down my 11 hp I/C Briggs & Stratton vertical shaft. When case split, the oil pump fell out. When re-assembling the case, does the oil pump rod ride on the spring loaded blade???? Thanks for any advice on re-assembly.
sirmowalot
06-06-2002 20:38:25
 Re: brigg 11 hp crankcase gasket re-assembly in reply to scott, 06-06-2002 20:18:26
Yes. You will also notice an area on the base side where the govenor/oil slinger is cradled in.
