Craftsman 42 mower
stooge
06-13-2002 16:03:42
Got a craftsman 42", 6 speed trans. mower.
Like to find trans. oil fill hole. Removed battery and saw a rubber plug in top of case, is this the correct filler hole?
chip
08-20-2004 14:09:47
 Re: craftsman 42 mower in reply to stooge, 06-13-2002 16:03:42
Did you ever get an answer on this? I have the same model of mower. I am having trouble with mine. I stood the mower up to change the blades and now the mower will not go forward or reverse. I let it sit for a while and it got better. Now it moves some, but the transmission is roaring.
Thanks
H.T. Bowen
04-08-2006 05:11:00
 Re: craftsman 42 mower in reply to chip, 08-20-2004 14:09:47
I stood the mower up to change the blades and now the mower will not start. Is it likely a safety switch?
Ron
06-14-2002 05:17:13
Not real sure about what transmission you have but alot of them--Peerless/tecumseh etc. have grease in the transmission & not oil. the rubber plug may just be a vent plug. You may want to go to the sears site & put in your model no. & see if the exploded view of the parts list show you anything.
rcjlwj
10-31-2004 18:40:58
 Re: Re: craftsman 42 mower in reply to Ron, 06-14-2002 05:17:13
I have the same 42 6 speed. The transmission is permanently lubed. There is no place to add our check the oil or grease.
