Cub Cadet 2160 electric pto clutch
PCC-AL
06-14-2002 14:30:54
looks like the pto is gone. I adjusted the air gap to specs and it worked a while, then went out again. Are these things repairable or do I have to bite the bullet and buy a new one. Anyone have a good source for clutches, used clutches or parts for them?? The ones I checked on the internet seem to run about $250.00. Thanks.
John
06-15-2002 06:35:10
 Re: Cub Cadet 2160 electric pto clutch in reply to PCC-AL, 06-14-2002 14:30:54
Have you tried to apply 12 volts to the electromagnet? It should hold a 1/2" X 3" bolt without falling off. If that doesn't work examine the lead wire for and broken spots, if that is ok you could tear out the old magnet wire, count the number of windings and replace it. If you have a friend who is into this sort of thing he might help you. John
Thanks John-PCC-AL
06-15-2002 07:55:51
 Re: Re: Cub Cadet 2160 electric pto clutch in reply to John, 06-15-2002 06:35:10
I can replace parts but not too good on repairing them. Guess I'll just have to buy the unit. Don't have an electric shop nearby. Thanks again.
John
06-15-2002 20:09:45
 Re: Re: Re: Cub Cadet 2160 electric pto clutch in reply to Thanks John-PCC-AL, 06-15-2002 07:55:51
Your Welcome! Where are you located it might be a simple fix and maybe I can fix it for you. Send me your email address. John
PCC-AL
06-17-2002 03:57:33
 Re: Re: Re: Re: Cub Cadet 2160 electric pto clutch in reply to John, 06-15-2002 20:09:45
Thanks for the offer. I haven't taken the clutch off yet, but will try to get it off in the next couple of days. I just haven't had the time to work on it lately. thanks again.
