73 cub cadet dies when it gets warm
steve
06-14-2002 17:09:55
after mowing for 20 minutes or so the engine dies,it will start right back up and run for 5-10 seconds. thanks for any help
jim
06-15-2002 02:56:31
 Re: 73 cub cadet dies when it gets warm in reply to steve, 06-14-2002 17:09:55
Check your fuel cap to see if the vent in the top is plugged. you may be creating a slight vacuum as you consume fuel, if there is no way to vent the tank. this prevents fuel from reaching your carb. had this problem on my rototiller. would start right back up & die again.
hmmm ...
06-14-2002 21:58:21
sounds like either coil or condenser
Art
06-16-2002 17:24:24
 Re: Re: 73 cub cadet dies when it gets warm in reply to hmmm ..., 06-14-2002 21:58:21
I am currently having the same problem with my K321. It will run 20 mins and shutdown. Restart when cool.
One of the tech. guys over at the Perr site. Said it may be a leaking head gasket that is causing the exhaust valve to overheat and stick. After cooling it will free up....Art
