317 charging system
John Bladen
06-17-2002 18:30:09
got a john deere 317 - wont charge bat., rectifier module replaced. Any clues?
thanx
John
Bob Jones
06-21-2002 16:04:49
 Re: 317 charging system in reply to John Bladen, 06-17-2002 18:30:09
I just went through the same problem on a 317!I put everthing on new and still weak charge. Next move is to replace the flywheel. Weak magnets can cause same problem. Waiting on a flywheel, to see if this solves the problem!!!
Red Baron
06-18-2002 19:02:02
Check to see if you have 12 volt on the center terminal of your rectifier. It must have 12 volt to charge.
Ron
06-18-2002 17:52:16
Are you sure the battery is good?
Bob
06-17-2002 19:52:15
Replace ignition switch.
john
06-18-2002 12:36:18
 Re: Re: 317 charging system in reply to Bob, 06-17-2002 19:52:15
thanx, Bob, I replaced the sw today, still no charge, I checked the stator windings w/ohmmeter, they measured ok, any ideas? thanx
john
Bob L
06-18-2002 19:14:37
 Re: Re: Re: 317 charging system in reply to john, 06-18-2002 12:36:18
Hey John;
My 317 did the same thing as yours. Drove me nutz for about 3 weeks till I checked and changed the Magnitic PTO clutch. It had a shorted winding, causing a high amp draw. The clutch can cause A LOT of electricial glitches, burn out what seems to be non related wiring, and be a general pain in the ..... .. well you know where. I got mine from Scheffel Equipment in Somerset PA, and paid an outrageous price, but, I had to have it.
Bob L
Shanksville PA
