18 hp Sears Craftsman II garden tractor
Irv
06-18-2002 17:19:29
I need to order some parts, but I don't know what the serial number of the tractor is, or where to find it. It is an 18 hp, 42 in deck, bought in 1988 - 89 Any help would be appreciated. Thanx, Irv - from Howell Mich.
dan
04-03-2004 11:48:41
 Re: 18 hp Sears Craftsman II garden tractor in reply to Irv, 06-18-2002 17:19:29
I have a 18HP craftman II garden tractor model 422707, type 1522 01, code 92100332, won't start. I replaced solenoid and battery. It only turnsover when jumper soleniod. what is my next step
Dennis Lemmon
05-23-2006 22:39:55
 Re: Re: 18 hp Sears Craftsman II garden tractor in reply to dan, 04-03-2004 11:48:41
Check to see if you have any relays, and if they are working. Had one rusted up a few weeks ago. It sounds like the syptoms.
Irv
06-21-2002 06:09:46
Thanks guys.
Mac
06-18-2002 18:49:59
Raise the seat and look on fender where battery is. Knowing how some of these people are, it may be inside the battery case housing..Sometimes where you least expect them to be. I was surprised the other day when I found some new cars have the battery's under back seat !!!!!
Ron
06-18-2002 17:46:12
Irv, Have you looked on the tractor for the serial number? Unless someone removed the tag the SN will be located on the tractor behind the seat or on the side. there should also be a tag located on the deck for mower info.
