Ford LGT 145 Carb
Mike
06-30-2002 07:03:05
Any thought on why I need to have the choke pulled to keep a Kohler 12hp (yes 12hp) running. Any help would be much appreciated
Stoney
06-30-2002 15:57:48
 Re: Ford LGT 145 Carb in reply to Mike, 06-30-2002 07:03:05
Your fuel and air isn't mixing correctly. Try some carb cleaner, you may have to disassemble and soak in solvent then be sure to use compressed air to blow all the circuits (air passages that look like tiny pin holes) out.
Brian G. NY
07-01-2002 07:59:06
 Re: Re: Ford LGT 145 Carb in reply to Stoney, 06-30-2002 15:57:48
Or.....it may be as simple as resetting the high speed jet on your carb; it appears to be running lean.
