Cub cadet transaxle lubricant
Danny McIntyre
07-01-2002 02:58:27
Need to know type and how much lubricant goes in the unit on a cub model 1730. This is the unit containing the gears directly under the pulley and cooling fan that sits under the battery. Owners manual does not give any info. Would greatly appreciate any information anyone can give me. Thanks in advance..Danny
Steve
07-04-2002 20:46:33
 Re: cub cadet transaxle lubricant in reply to Danny McIntyre, 07-01-2002 02:58:27
Danny:
I have the Service manual. I assume that you are referring to the "input" shaft on the transaxle. The pulley from the engine mounts to this shaft, right? This is called the "input assembly. The manual says to pack it with 5 ounces of "Durino-O type grease" before remounting the input shaft. I just used a high grade bearing grease on my 1720.
Al Dziennik
08-06-2004 06:41:14
 Re: Re: cub cadet transaxle lubricant in reply to Steve, 07-04-2002 20:46:33
wrong. input and output shaft are located under the pump. when pump is removed you'll find two couplings. one is input to pump and the other is output to transmission. grease both of these with a really good grease because they aren't something you'll likely get back to in quite a while because of their location.
Danny
07-05-2002 02:18:13
thanks Steve..... .and to all who helped,,,Danny
use HY-TRAN ...
07-01-2002 06:45:26
... it's the best for yer Cub. You can get it from any Case IH dealership. Cub dealers may have it under another name, too.
Also, when ya change the filter, make sure ya get a hydraulic filter; a regular car oil filter, while it may fit, will not filter out enough dirt.
Danny
07-01-2002 17:31:48
 Re: Re: cub cadet transaxle lubricant in reply to use HY-TRAN ..., 07-01-2002 06:45:26
this unit seems to be separate from the hydrostatic drive fluid. the hydro is full and this box looks like it has been bone dry since 1962. was wondering if maybe it packs in some type of special grease instead of having a fluid? thanks for your input on the hytran
Glenn(WV)
07-02-2002 06:40:16
 Re: Re: Re: cub cadet transaxle lubricant in reply to Danny, 07-01-2002 17:31:48
Danny, do you have the manuals for it?
Danny
07-02-2002 07:09:27
 Re: Re: Re: Re: cub cadet transaxle lubricant in reply to Glenn(WV), 07-02-2002 06:40:16
re glenn(WV)...have the owners manual and all it says pertaining to the transaxle is refer to your dealer.,,just looked on an exploded parts view that I obtained and they call it a transmission instead of a transaxle.
v
