CUB CADET MOD. 102
Scott M. Harris
02-04-1999 20:37:20
Thanks Don for the clutch assembly. Now, I have question for anyone out there. On my 10hp Koeler
engine in the front is the PTO. How does this function? Also, are the pullies, both the main and the blower, supposed to be loose on the shaft? I looked and there are set screws, so I tightend them. Is there anything else I should know about this? Thanks, Scott
don
02-05-1999 04:06:46
 Re: CUB CADET MOD. 102 in reply to Scott M. Harris, 02-04-1999 20:37:20
the pully part will wiggle a little bit , ithe starter pully was real loose i would suggest removeing the whole assy to check the crank & key i have seen the key way on the crank get wollowed out. when the lever for pto is released the pto will engage there should be three fingers & a button in the center there should also a button on the arm that pivotes in the grillthese two should be the contact points if you need a break down i could fax 1 to you 920-533-5340 i also have parts for this
Scott M. Harris
02-05-1999 05:06:34
 Re: Re: CUB CADET MOD. 102 in reply to don, 02-05-1999 04:06:46
I took the blower pully off, the bearing underneath looked good. The starter pully was wobbly, but not able to rotate completely around. My guess is that the key is still intact. I just tightened the set screws. How do you adjust the pivoting lever that ingages the PTO? I know there is an adjusting mechanism on the side of the engine. But should the the two buttons be in contact with each other while disengaged?
don
02-05-1999 15:18:37
 Re: Re: Re: CUB CADET MOD. 102 in reply to Scott M. Harris, 02-05-1999 05:06:34
you want a little clearece there not to muchor it wont disengage
Scott M. Harris
02-05-1999 15:46:59
 Re: Re: Re: Re: CUB CADET MOD. 102 in reply to don, 02-05-1999 15:18:37
Thanks for the info. I'm in need of a mower deck for this mod. If you know of any, please let me know. Thanks, Scott
don
02-06-1999 04:45:57
 Re: Re: Re: Re: Re: CUB CADET MOD. 102 in reply to Scott M. Harris , 02-05-1999 15:46:59
don't know of any now expect to get one or to before spring
