4, 6, 8, 10 edge blades
Boyd
07-03-2002 00:29:30
Murray and Cub Cadet had a mulching blade about 5 or more years ago for their 30" deck. It had at least 8 or 10 edges on it mounted to a big hub. It is discontinued. Wouldn't a 4 or more edged blade work better than 2. I know there is a company that makes aftermarket ones but they have very short blades and don't look like they would have much vacuum lift. Why don't most all manufacturers make 4 or more edged blades?
Max
07-04-2002 09:17:13
 Re: 4, 6, 8, 10 edge blades in reply to Boyd, 07-03-2002 00:29:30
try two blades, one a medium lift and the top mounted blade a low lift. Have the top blade sharpened closer towards the middle than the lower one and you will be amazed with the way it mulches. Just be sure the the lower blade isn't lower than the side of the deck, for if its lower, then there is a chance for thrown objects.
Ron
07-03-2002 04:15:47
Hi Boyd, I can't answer the question you pose, but there are mulching blades made by Gator that may
fit your application. Do a search for Gator blades. These blades are pretty aggressive looking & are available in hi-lift styles.
Gatorblades Web site
07-04-2002 19:07:38
 Re: Re: 4, 6, 8, 10 edge blades in reply to Ron, 07-03-2002 04:15:47
