1811 Cub Cadet
Ron
07-05-2002 11:58:07
My Model 1811 Cub Cadet dies when it is hot, and won't restart until completely cooled down. I understand that the electronic ignition coil is probably the problem. Can this coil be changed without removing the motor from the tractor?
Kevin
07-07-2002 06:50:55
 Re: 1811 Cub Cadet in reply to Ron, 07-05-2002 11:58:07
Check your valve clearance.I have had a few of the older Kohlers act the same way if the valves are too tight.An easy check is to pull a spark plug as soon as it stops & check for spark & compression.That should point out your problem.
Steve In MD
07-05-2002 21:25:08
Yes and its an easy fix. The Kohler engines are prone to this problem. I had to replace the coil on my 1720 for the same reason last year.
- Steve
