Craftsman vs John Deere
Skip
07-14-2002 13:22:10
I'm about to buy a lawn tractor and cannot afford a Cub Cadet, so I'm looking at Craftsman 27502 and JD LT-180. They appear to have most of the same mechanical components, so can anyone convnince me the JD is worth the extra money?
Thanks!
Jonathan
07-17-2002 17:51:59
 Re: Craftsman vs John Deere in reply to Skip, 07-14-2002 13:22:10
I believe the sears and JD lawntractors are about the same quality, I see you have been going about looking at them in a smart way. There is a huge difference between a craftsman "garden tractor" and a JD. My dad bought his back in '98 as a used dealer demo rig with a snowthrower and chains (which is needed around here every winter), that was used to clear snow in front of the store. It was a craftsman "garden tractor" 19.5hp GT. It has a kohler engine. He bought the entended service contract for I think either 2 or 3 extra years and paid good money for it, of course with the pestering of the "shoe salesmen" clerk at sears. We had the tractor for a few months and everything was going great until I accidently bumped a tree with it while mowing the front lawn. The bump wasn't even hard enought to dent or break anything, but somehow totally screwed up the engine so that it wouldn't run right and when the mower was engaged it would just about stall. We went to sears and told them the tractor had developed problems and they told my dad that they had absolutly no record of the service contract and that if he did want it fixed, he'd have to send it way away to a sears shop in calamazoo and pay all the expensive fees and a high hourly repair rate and all kinds of B.S. Our local sears store is small and we have learned not to buy from there anymore because they are totally unwilling to exchange defective products or make things right with the customer. My father also bought an angle grinder from there and found that it turned in the wrong direction, so he took it back the next day with the recipt and they refused to exchange it, good thing he's an electrician, so he took it apart and found they had put in the brushes or something in backwards and he fixed it and is still using it today.
We kept the tractor in the garage for a full year and a half (the engine was so messed up the tractor was unuseable) and kept needling the sears guys about it but they wouldn't budge. We of course didn't dare to touch it ourselves because that would have voided the service contract and he had hopes of sears making it good. Finally we fixed it enough so we could use it, but, it's been far from right since and when tipped a certain angles it will do weird stuff, like there is a certain spot in the drive way that the engine will rev like heck on it's own. Other angles will cause it to load up etc... I expect it's the carb but I'm not sure.
I firmly belive in JD's nice line of garden and compact tractors, those are really nice and would never wear out if well maintained and not abused, but I see you've already found out about the "nice" pricetag they have after reading one of your posts on the JD 455, but you gotta figure it would most likely be the last tractor you would ever have to buy if nothing happens to it, garage burns, stolen, etc... Of course for the cost of that one you could buy almost 4 craftsman lawntractors, but I belive the 455 has power steering, bigger platform and easier to get on and off, a diesel engine which should outlast a gasoline engine by a long shot, but watch those fumes, a bigger wider mower deck, a much more powerful engine, a greater variety of implements made for the tractor and I think possibly 3pt?, larger tires, a pto of some sort for attachments, etc... thats quite a few plusses and over the years, especially when you get older, some of those you would be thankful for.
Another big plus is deere dealers carry alot of parts and can get them right away if they don't have them, but of course green parts cost alotta green, but it would be worth it if say you were losing money by not being able to use the machine. I don't really know where sears stands on parts. I know the salesmen at our store don't seem to know a sparkplug from an oil filter and can't fix anything there, they send all their stuff away.
Tyler jakins
12-09-2002 15:19:55
 Re: Re: Craftsman vs John Deere in reply to Jonathan, 07-17-2002 17:51:59
I think that my John Deere will out haul eny Craftsman my John Deere 140 has given me awsome servicefor 34 years.I have pulled out maney snake barry bushes that have an 3 inch base an Craftsman would have blown its rear end .Some of my friends have Craftsman that last for 4 or 5 years I call them throw away tractors. They are made out of your recycle tin cans it seems like.
Mark/Ks
07-17-2002 10:54:16
Skip, If you would, let us know what you end up Buying... I would like to know what you decided to buy and what persuaded you.... Thanks...
DuaneW OH
07-17-2002 06:48:01
While all the JD guys are bashing everyone else, another tractor you SHOULD consider is the simplicity. If you just want your grass cut and dont care what it looks like, buy the cheepest and replace when needed. JD does make a good tractor, mowers are just avg. when it come to quaility of cut. I could not afford the 455 JD when I bought mine (1 yr ago), so I ended up with a cub cadet 3206 w 54" deck. What would be ideal is a 4/5 series JD tractor with a 60" Cub Cadet mower deck under it. In case your wondering, the Simplicity I wanted was priced the same as the JD 445 ( more than I could spend ). The Cub and Simplicty mowers both have full rollers on mower, hard to scalp and very good for leaving patterns in yard. Also doesnt leave uneven lines from tractor hitting hole/high spot like a suspended mower will. If yard is real rough, it will tear anything up, hard to have a valid opinion on exactly what to by with out looking at ground and your opinion is really the only one that matters to you. JD Tractors will outlast sears tractors because parts are available longer and cheeper to fix than replace a deere.
Duane.
John
07-16-2002 19:14:37
Skip, I bought my first John Deere 140 (used) back in 1977 and my Dad thought I was crazy for spending so much money, I wanted something that would last. I still have the same 140 and it has been overhauled, but other than just normal maintence it still runs like a top. My Dad has an old tractor junkyard full of Craftsman, Toros, MTDS, and various other tractor names that are just not worth fixing. It doesn't take a rocket scientist to figure out who has spent the most money on tractors over the last 25 years. I have three sons who have each took their turn mowing our two acres and in addition our neighbors 2.5 acre lawn for at least three years. I will never sell my original JD140 and when I die my sons will have to fight over it, by the way I have two other John Deeres now a JD300 and a JD400. I highly recommend a John Deere. Good luck in trying to decide, but reading all the responses it is kind of hard to ignore that John Deere is the best choice. John
Ted
07-16-2002 10:32:27
Skip,
If you're interested in the John Deere's quality but don't want to spend the money for the "GREEN" paint job take a trip to Home Depot. The Scott brand is manufactured by John Deere. It even has the decals to prove it. The Scott brand is an exact duplicate of the John Deere with the exception of two things. The paint job and price tag! I just purchased a Scott 17hp/42in on sale at Home Depot for $1,399. The same mower with green paint would have cost me over $2,000. These mowers are built to last! Steel frame, Heavy guage steel mower deck, INTEC motor and CAST IRON front axle! Just my 2 cents.
mhmalcolm
07-16-2002 19:10:43
 Re: Re: Craftsman vs John Deere in reply to Ted, 07-16-2002 10:32:27
It is not exactly true that the Deere built Scotts brand machines are the same as the John Deere branded machines. They are the same as the "Sabre" brand tractors made by John Deere and sold by John Deere dealers. The Sabre and Scotts tractors are built a little less heavy and are less money than the "John Deere Green" tractors,but are a good value for the money. Incidently, the prices of the Scotts and comparable Sabre machines are about the same, but since a Deere dealer has to do the warranty repairs on both the Sabre and Scotts machines since Home Depot has no servicing capabilities, you may end up dealing with a Deere dealer anyway. I kow this because I work for a Deere dealership.
Skip
07-17-2002 01:02:22
 Re: Re: Re: Craftsman vs John Deere in reply to mhmalcolm, 07-16-2002 19:10:43
Ted, I replied to your posting earlier but I have a feeling I did something wrong and it never got posted . . . so forgive me if this is the second one. Since you work for a JD dealer, maybe you're the guy who can answer my original question instead of all this "JD's are better" stuff I've been getting. I'm a mechanical engineer, so things mechanical are nothing mysterious to me. I've looked over both the JD LT-180 and the comparable Craftsman DLT2000. The DLT 2000 has a 10 gauge deck with four gauge wheels, greasable mandrels and a nose roller. The gauge wheels are mounted to the deck in what appears to be a stout manner, unlike the cheaper Sears decks. The engine is a 20 HP Kohler, the hydrostatic drive may or may not (do you know?) be identical to the one in the JD unit, and like the JD, the Craftsman has a plastic hood and dash, enviable features for life in Hawaii where the State Color is rust. I've spent some time looking over (and under) the JD lawn tractor and I can see really no difference in quality of construction. The JD uses a Kawasaki engine and I know nothing about these. The Kohler is proven and I've had several that gave exemplary performance for many years.
So my question remains: The Sears unit is $2600 and the JD is $3400. I am open to some intelligent discussion on specifics of how the JD is worth the extra money. Sears, in Hawaii, does a terrific job with service and repair, too. We just bought a 3-acre farm and the seller showed me his 8 yr old Craftsman garden tractor which which he's been mowing the fields twice a month for all those years. The machine showed little signs of any maintenance, was covered with rust, but still did the job. The owner told me that Sears was right out there with same day service for the duration of the 3 yr warranty to repair anything that went wrong, including belts, a battery, a tire, and tuneups! Since the expiration of the warranty, repairs were limited to a drive belt every year and a deck belt every other year.
I'm still open, though. I know all about how terrific the older JD machines were, but I need real-time input on what's available now. I'm willing to spend the extra money, but only if I am convinced it's worth while. I've heard, and it is plausible seeing as how everybody else is doing it, that JD has used its good name to promote its consumer line of lawn tractors, at the same time downgrading them to basic consumer quality. Any feedback on this?
I'm listening... Aloha!
mhmalcolm
07-20-2002 18:22:18
 Re: Re: Re: Re: Craftsman vs John Deere in reply to Skip, 07-17-2002 01:02:22
Sorry it took me so long to reply but I've been out of town. Im the guy that works for a Deere dealership. I am the parts manager and don't know all of the comparisons between the Deere machines and the Craftsmen machines that the salespeolple know, but from a parts person's view, I can tell you a few things. First of all, I have alot of parts customers who own Craftsman machines that come to us looking for parts for their machines that are between 5 and 10 years old because they can't get them through Sears anymore. Most parts for Deere machines that we don't have in stock we can get by the next morning. We even have some Craftsmen customers that are able to get parts through Sears, but come to us after weeks of waiting for ordered parts from Sears to find out if we can get an equivalent part faster. Sometimes we can and they are usually less expensive. Many of these customers end up buying Deere machines because they are sick of the frustration of poor parts availability and general lack of customer support. Judging from the info I have gotten from Craftmen customers over the years that have converted to Deere, they not only feel the Deeres are more quiet and comfortable to operate and seem to have fewer breakdowns when used in rough conditions, but like the fact that they can usually walk right into our dealership and get the parts they need to get them going again in a matter of minutes.
Just some honest observations.
dean
07-19-2002 05:30:05
Skip,
I have a Craftsman 2000. I purchased it about 15 months ago. It is a decent unit. The features that you identified are why I bought it. The heavy gauge deck, rollers, greasable mandrels, Kohler engine etc. A couple of thoughts on the tractor. It is very comfortable to use, I mow about 2.5 acres with hills and some fairly rough terrain. The Kohler engine is a real jewel. It runs like a top. The mower deck does a nice job of mowing, provides an even cut and does a decent job of spreading the clippings. There are a couple of items that have been problematic. At about 20 hours of use the plastic discharge shield broke. Sears replaced it with a heavier better designed model. The nose roller didn't deal well with a small stump that I didn't see. The brackets were bent and the roller rendered useless. The ventilated mower deck attracts grass clippings in a hurry. If they are dry they can be removed easily with a leaf blower, however if they are damp you need to get under the unit and take them off by hand. The greasable mandrels are nice, however it is a little bit of a problem accessing the middle one. Very recently the deck lift lever starting acting up, I am making a service call to get that resolved. The unit is still under warranty. Also, I have had trouble at times with the drive belt coming off. Not a big deal to put it back on but a pain never the less. All in all I am satisified with the mower, I looked at almost everything out there and purchased this because of the price. Our Sears dealer can't keep mowers in stock. He sells several hundred each year. They have been good to deal with. My old tractor was a JD, and I would have purchased another but I was moving up in size and the thought of spending 4-5k was out of the question. I did not buy the hydro, most of my mowing is in large open spaces so I don't need to manuever in tight quarters. I paid $1,900. I do not bag clippings, I have a good friend who owns a hydro model and bags. He reports very good luck with that. His mower has been very reliable. Hope this helps.
Dr. Evil
07-18-2002 09:00:50
I don't know how many 20+ yr old Cub Cadets are in the islands.... but if I couldn't get one of the old IHC Cub Cadets, or and early MTD equivalent.... I'd buy a Simplicity. I sure wouldn't spend My $$$$ on a Craftsman! EVERYONE I've ever talked to that's had one has complained about them. My oldest Cub Cadet is 34 yrs old... last repainted 22 yrs ago... still looks great. Keep Your equipment "Inside" out of the weather and I bet it lasts longer and doesn't rust.
Jim
07-15-2002 23:03:15
In the last year through several different trades, I have owned six different garden tractors. I am not a JD fan, but Craftsman tractors are not comparable in durability or design. Again it depends on how much you will mow. I am going to go out and mow with my 1966 Case.
Jim
07-15-2002 18:31:40
I went thru the same process as you. Spent close to three months reviewing data. show room shopping.. Your descion needs to based upon yoiur application and need. The Sears products were in IMHO were less than average. Lots of Bolts .. bigger enegines yes.. but poor workmanship. The Cub's are a nice machine.. the only issue I had were the size the rear tires.. 9's vs 10's on the lawn tractor model. The JD was and based upon a review in Popular Mech. a superior product.. YES it's cost more.. but take the time to realy look at the build vs the MTD and Sears..
B.S.
07-15-2002 12:10:47
MTD cadets and craftsmen, and all others are junk. If you want a good heavy duty garden tractor go with an IH built CUB CADET. even if your a poor SOB spend the welfare check and get an old IH CUB CADET.
Dr. Evil
07-18-2002 09:03:24
 Re: Re: Craftsman vs John Deere in reply to B.S., 07-15-2002 12:10:47
He just bought 3 acres in Hawaii.... He "WAS" a multi-Millionaire...Now He's BROKE!
Skip
07-18-2002 11:31:09
 Re: Re: Re: Craftsman vs John Deere in reply to Dr. Evil, 07-18-2002 09:03:24
Actually, the three acres has a small home and a barn, a beautiful ocean view, and we paid $130,000 for it. Don't beleive it? We live in Hawaii for many reasons, and not the least of them is that we can afford to live here. If you're interested in finding out more on this subject, e-mail me at thomsen@mailbooks.com (Since we can't "advertise" on this forum).
Denny Frisk
07-18-2002 15:10:00
 Re: Re: Re: Re: Craftsman vs John Deere in reply to Skip, 07-18-2002 11:31:09
WOW... I'd heard land was extrordinarily expensive! That's cheaper than My part of Wisconsin! and I don't have the ocean view!
Steven Wood
07-15-2002 11:34:14
Craftsman tractors are actually very nice machines. John deere needs to realize that their competitors are producing equal or better machines for less. MTD has grown up over the past year and now is a good competitor for the big names, like John Deere. I would say, buy the Craftsman, it is cheaper and has the same features, and will last almost as long if not as long as the JD.
Jonathan
07-15-2002 11:31:54
If I was you and had the extra money to spend, I'd go with the Deere. The crapsmen my dad bought back in '98 has been nothing short of being a junk. We used it very little here on our place and have had one heck of a time with it. If you do buy a crapsmen, the salesmen will try to push their extended warranty crap, DON'T buy it, it costs alot of money and they WON'T fix it if you do have problems, Been there and done that!.
Stven Wood
07-15-2002 11:39:42
 Re: Re: Craftsman vs John Deere in reply to Jonathan, 07-15-2002 11:31:54
I may put myself in hot water and am not as reputable as some of these people, being a Gravely fan. But MTD produces their best machines for Craftsman. Craftsman's equivalent is Cub Cadet, MTD's top line. MTD is evolving into a totally different company, and is better, in my mind, at parts and service than others.
Skip
07-16-2002 22:58:44
 Re: Re: Re: Craftsman vs John Deere in reply to Stven Wood, 07-15-2002 11:39:42
I like what you're saying, but you sure are in the minority! I hear all this JD enthusiasm but have yet to hear any specific on why a JD is a better machine. Your reply is more in line with my own personal research . . . but I'm still trying to get sime difinitve answers from the JD fans out there.
Thanks!
Mark/Ks
07-15-2002 11:04:58
Bought a Craftsman Six years ago, Has the 18 HP Kohler engine. Paid $2300 for it, and has 46 inch cut. Only problem so far is a bearing in the
deck hub lost a seal and went dry.. I replaced that myself. Have given this thing good maintenance. I think it will last a good long while with regular maintenance... But, the steering is really cheap!! Oh, We mow 1.5 acres with it twice a week durring spring and fall, then
once every two week durring summer.. I think John Deere are fine machines, But for me and my money I went with the Kohler/Craftsman..
Richard
07-15-2002 09:41:52
Skip I just went through what you are doing now. The big question is how much grass will you be cutting ? I have 3 acres of grass and looked hard settled on the deere GT245 with 54" cut. and yes it's pricey but it runs quieter, and vibrates a hole lot less and is a bigger tractor. also deere has awesome financing deals now. After 30 days of mowing grass I'm really glad I settled on a Deere, besides 20 years from now my granddaughter will be using it.
Steve from MO - do you have to buy new?
07-15-2002 07:50:07
You might consider an older JD, Cub Cadet, or Wheel Horse. Case/Ingersoll would be good, too. Keep part fo your money back for repairs/fixup.
bob
07-15-2002 07:39:52
8 years ago I bought a 322 JD after fighting mtd,s briggs motors etc. Of course it was spendy and is water cooled which I think is the answer. But if I figured at this time it has cost me less and I still have a SALEABLE MACHINE. i WAS NOT A JD FAN BEFORE DEpends on how much you mow too
Rusty
07-15-2002 05:16:09
I asked myself the same question 7 years ago and decided to go with the Craftsman. I have regretted that decision constantly for the last 4 years as the never ending repair bills keep piling up (not including the items replaced undeer a service contract the first 3 years). Get the Deere.
Junkman
07-14-2002 20:05:39
I am also a John Deere fan so take my words for what they are worth. I have a 2000 model 445 that I would not trade for any other make. The Cub Cadet and the Craftsman are built by the same company, MTD. As far as I am concerned all they make is garbage. They are into quantity not quality. Good luck.
Briggs_Man
07-16-2002 05:53:21
 Re: Re: Craftsman vs John Deere in reply to Junkman, 07-14-2002 20:05:39
Need to get some facts straight their,, Craftsman's are built by AYP Not Mtd, I have seen Many many AYP's and Mtd's go for years, And Metal hood not some POS Plastic Green/yellow hood
Junkman
07-16-2002 17:09:21
 Re: Re: Re: Craftsman vs John Deere in reply to Briggs_Man, 07-16-2002 05:53:21
You know Briggs_man, you got it all figured out. Buy a tractor because it has a metal hood, not because it is a quality machine. Lets compare your POS Crapsmen to my plastic hooded John Deere. Then lets do it in 10 years, and while we are at it 20 years too. Wake up and smell the coffee.
Briggs_Man
07-17-2002 11:00:41
 Re: Re: Re: Re: Craftsman vs John Deere in reply to Junkman, 07-16-2002 17:09:21
I Cannot justify spending more money for the same damn mower more or less, I have a 1999 Craftsman, 14.5 Briggs OHV engine. 42 inch deck. 345 hr's Gets used all year around. Mows grass, Pulls Trailers,Shoves snow, Still have yet to replace either belt, Deck or drive, Take a JD 14.5 hp and a AYP 14.5 hp both with 42 inch decks. Grease fittings on steering and Front wheel's, They both do what CUT DAMN GRASS thats what, with regular maintnace my Craftsman will out live your Johndeere and will be Less expencive to maintain, I Get so damn sick of this attitude JohnDeere rules all others are Junk, BS, Thats all it is is BS, Green and yellow paint must be alwful expencive. Looking at a ad now for a LT150 JD 38 inch cut, 5speed trans, 15 hp engine,, For 2,199. Huh i got a AYP for 1,200 and compared to a higher priced johndeere i gained 4 inchs to the cut gained 1 more gear,and to it im 1/2 a horse short, whaaaaa aaaaa i got more for less wouldnt we say, JD and their notpulling carts with the Lt mowers turn me off also, are they admiting they build Junk or what,,, Yes yess yes the older JohnDeeres were great The newer ones i cannot say that about em at all. High priced and Paying for the name, JunkMan If your 445 is a Diesel it is Not a JohnDeere sir its a Green/yellow painted YANMAR
Junkman
07-17-2002 20:08:05
 Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Briggs_Man, 07-17-2002 11:00:41
You open your mouth and show how stupid you are. The 445 is a gas tractor only. 455 is diesel. Your Crapsman will never outlive mine. Mine will be given to my kids to use (and I'm only 32). Read the rest of the posts, Crapsman breaking down, John Deere living. You get what you pay for, crap don't cost mucharound here, but it sounds like you pay dearly for it. You married to your cousin too, or didn't you get that far form the family.
Briggs_Man
07-18-2002 16:58:33
 Re: Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Junkman, 07-17-2002 20:08:05
Your Crapsman will never outlive mine. HMMMMM MM well while your sitting their Naming me stupid, your JD is a 2001 my AYP is a 1999, Outlive . Son it already has your johndeere beat by 3 Years and 300+ HRs and i doubt it will be alround to hand down to your kids if you think it will last as long as the older ones did the only fool is you. Your attitude is what makes my stomach turn against JOHNDEERES
Briggs_Man
07-18-2002 15:54:22
Excuse me 445 Gas 455 Diesel,,, Hmmmmm mmm the stupid one is the one calling names.
Skip
07-17-2002 01:17:17
Y'know, this is beginning to sound like the arguments I used to endure in high school about whether Fords were better than Chevys. What I would like to hear are some SPECIFICS on why is a JD a better machine? Hey, I live in Hawaii and I love the idea of a plastic hood. The metal ones are solid rust in two years. So here's my question: In what specific ways is a JD LT 180 $1000 better than a Craftsman DLT 2000. The Sears unit has a 10-gauge deck with 4 gauge wheels, greasable mandrels, a 20 HP Kohler engine, and from what I understand, the identical hydrostatic drive as the JD. The Sears machine even has a plastic hood!
I don't want to hear how good somebody'w 1965 JD tractor was/is; I know all about them. I am no stranger to old equipment, having had lots of it in years gone by. They don't make them like that any more. You cannot compare a new JD LT-180 lawn tractor to a 10 yr old JD tractor. They are not the same animal. JD now builds a consumer line of lawn tractors and I still would like to hear from somebody who really knows the specs and the facts just why it would be to my advantage to spend the extra money on a JD. I'll do it if somebody can convince me! I'm willing to come up with $3-4000 for a good lawn tractor that will handle 3 acres of mowing twice a month. I will not pay $5-6000 for a top-of-the-line anything, so let's compare apples and apples. The Sears machine, BTW, is $2600 here and teh JD-180 is over $3400.
Thanks for your time!
Junkman
07-17-2002 10:48:11
 Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Skip, 07-17-2002 01:17:17
Skip, I am not familiar with te LT 180 John Deere. I will tell you that my 445 is a well built machine, solid frame, cast iron front axle, and all shaft driven. I also have a Kawasaki engine on mine and it seems to be very well built. Look back 40 years and you will see that John Deere has proven itself. How long has Craftsman been around? How many people do you hear talking of the Craftsman tractor they just rebuilt? None because they are not worth rebuilding. Let history speak for itself, go with the Deere.
ironhead
07-17-2002 17:23:00
 Re: Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Junkman, 07-17-2002 10:48:11
hey junkman, i have to agree with briggs man here. i have 2 30 plus year old sears garden tractors. (by no means a craftsmans) and also had 1 jd 330 with that piece of crap yanmar diesel. both of the sears tractors have never had any major work , only belts, plugs and oil. that green thing wanted every part it had. green was the worst, by far , investment i ever had compared to all my other colors i did not bring up. granted, you are right as far as todays craftsman models being poorly made. but look at that green thing you have. i mean , comeon. plastic all over tin for metal, mower deck wheels so thin they cant touch the ground with out breaking. So while you all sit here and argue , im going outside to pull somemore jd's around.
Junkman
07-17-2002 19:58:57
 Re: Re: Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to ironhead, 07-17-2002 17:23:00
Ironhead, you had experience with 1 John Deere, obviously it was a bad one. You must know nothing of the new John Deere's. My mower deck you could not pick up, the wheels are very stout. The tractor has only 1 belt on it, that is the one on the deck. If you want to be pulled around, come see me i'll make sure it gets done right.
ironhead
07-18-2002 14:23:07
 Re: Re: Re: Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Junkman, 07-17-2002 19:58:57
yes, just one myself. let me tell you something though. i have neighbors and friends and coworkers who i talk to all the time about tractors.(a good bunch of people) i only know of a few people who had good luck with deere. im not saying craftsman or sears is better, just that all the deere (past)owners will never own another, including me. the parts are way over priced, and if you have to take it to the dealer for anything you might as well stretch your legs and back because you WILL be bent over the table. i remember when iwas a kid, i loved JD. but i grew up and got wiser. all JD is , is just another name out there.
Briggs_Man
07-17-2002 18:08:50
ROFLMAO Couldnt have said it better my self, Just like whene JD Owned homelite, The trimmers were the biggest POS's i ever worked on Now tell me who's . Name was JD trying to ruin their self or homelite Cause both names was on the trimmers. Sorry i had to tell customers their trimmer had had it
Skip
07-17-2002 13:29:44
I just looked up this JD 445 I keep hearing about. Well, for nearly ten grand it oughta be a better machine than a $2600 Craftsman. I'd still like to hear someboody tell me in what ways an LT-series JD ( the only one that I can afford and quite comparable in specs wth the Craftsman DLT-2000)is worth nearly $1000 more than the Craftsman. Yes, if I could choose between a JD445 and a $2600 Sears mower I'd choose the JD in spite of the complaints I read on epinions-com.
So my question STILL STANDS UNANSWERED after all these postings: In what specific ways is the JD LT-series lawn tractor better than the Sears DLT-2000? The DLT-2000 has a cast iron axle with spindle zerks, a 10 gauge steel deck with four gauge wheels mounted in very stout brackets, greasable deck mandrels, a 20 hp Kohler engine, a hydrostatic drive that I hear is mfgd by the same folks who make the one for JD, and last but not least, a plastic hood like the JD, which is fine here in Hawaii where at least that's one part that won't rust. It seems that a lot of teh guys knocking Craftsman equipment haven't looked at any of their newer high-end offererings. I've spent some time inspecting the JD mowers and I just can't find any mechanical differences worth noting. Now if that low-end JD only had a shaft drive . . .
Any answers?
Thank you!
Mark/Ks
07-18-2002 05:44:13
 Re: Re: Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Skip, 07-17-2002 13:29:44
Skip, I have the Craftsman, I'm not trying to persuade you in any way. But you might check the steering setup between the two. My Craftsman is not all that great. (It works fine but leaves something to be desired.) The front wheels, do both have bushing, my Craftsmans is bushing, I think bearings would be better. Are both engines bolted directly to the frame?? Mine is and It would be nice if it had rubber mounts to absorb some of the engine vibration. (But the Kohler is not all that bad either). Are they both easy to work on?? I.E. changing belts, plugs, oil, Etc.
Again, Let us know what you decide to get, and what your rational was in you decision... Thanks..
Briggs_Man
07-17-2002 11:17:15
Junkman you cannot compare Craftsman to anything , Craftsman does not build mowers, AYP American Yard Products Builds Craftsman, Husquvarna,Some Statesman's Weedeater brand, CubCadet is Built by MTD, Johndeer's Diesel's Are Nothing but a Yanmar, And possiable Gas versions as well as yanmar builds a Gasoline version,
Junkman
07-17-2002 19:51:41
 Re: Re: Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Briggs_Man, 07-17-2002 11:17:15
You know it all Briggs man. Yanmar is owned by John Deere. Does your POS crapsman have a Sears built engine? I think not. Can you tell me who rebuilds Crapsman tractors? Nobody with half a brain!! Let's talk resale, Crapsman has little if any. John Deere holds value for many years. You pick Crapsman and Briggs to be proud of. Man move out of the ghetto.
Briggs_Man
07-18-2002 15:58:44
 Re: Re: Re: Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Junkman, 07-17-2002 19:51:41
I may not know it all but you act like you do ,,, and resort to name calling, and bla bla,, Your Just making yourself look like a Great big idiot... By the Way Johndeere does not own Yanmar. You have been sniffing way to much deere touchup paint i can see that ROFLMAO... Hmmmmm mmm anyone notice he gets so up tight about deere but his nic is junkman, Well that sums it up Johndeere is junk Roflmao... J/Kng
ironhead
07-18-2002 16:21:55
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Briggs_Man, 07-18-2002 15:58:44
you know, i was going to say something earlier about that , but just couldnt. glad someone did.
Rich
07-17-2002 05:02:20
Skip-
Check the warrantee's too, with JD it is two years on almost all components, and if your not satisfied after the first 30 days, they offer a no questions asked return for your money back guarentee..... Not bad.
Stven Wood
07-17-2002 06:41:11
 Re: Re: Re: Re: Re: Re: Craftsman vs John Deere in reply to Rich, 07-17-2002 05:02:20
So does Craftsman, but for the duration of the warranty.
Dave
07-14-2002 18:59:56
Skip,
It boils down to three things: Parts, Service, Reliability.
I've owned nothing but Deeres. I have owned brand new units, and I have purchased used units. Parts are still available for 1963 John Deere 110s, with a few exceptions. That's nearly 40 years. I doubt that you'll find a 40 year old Craftsman and be able to find new parts for it through Sears.
Deere publishes service and parts manuals that are great. I've been able to do things myself, that without their manuals, I'd not want to attempt. Their dealer network is also well established, althogh some dealers are better than others. (But then some Sears stores are better than others.)
On average a John Deere lawn or garden tractor, will retain 48% of its purchase price after 4 years. A Craftsman loses about 50% of its value after two years. By the end of four years, its value is at about 25% of its original purchase price.
Follow your heart on this one. Buy the one you like the best, and enjoy. 100 years from now, it won't have made any difference anyway.
Dave
Dr. Evil
07-18-2002 09:11:11
 Re: Re: Craftsman vs John Deere in reply to Dave, 07-14-2002 18:59:56
Buddy of Mine sold a Cub Cadet 72 and Cub Cadet 73 for $1700 for both tractors couple months ago. Dad bought a 1963 Cub Cadet 70 for $675 including a 38" mower...Your Deere's may be holding their value well, but old IHC Cub Cadets are APPRECIATING in Value. Not much for parts You can't buy new for them either... thru a Cub Cadet OR Case/IH dealer. And EVERYTHING is available used.
Steve C.
07-14-2002 16:29:21
I'd walk right past the Craftsman to the John Deere. But then, I'm a John Deere fan-atik, especially older models.
Jim Broughton
07-15-2002 21:59:49
 Re: Re: Craftsman vs John Deere in reply to Steve C., 07-14-2002 16:29:21
Can you stand one more vote for the "Deere"...I bought a 1971 John Deere 140 in 1973, with all attachments and hydraulics. I've mowed up to 3 acres ata time with my 48" mower deck and except for routine maintenance plus one valve job, it runs beautifully !! Heck, even the lights still work !! Needless to say, I wouldn't trade it for anything !! And yes, you can still get parts at your JD dealer (mine has a Kohler original engine) Lots of luck !! Jim
