Ford LGT 16 into dually
joe legge
07-20-2002 10:43:16
how can i make a dual wheeled garden tractor?
Steve Johnson
07-20-2002 21:15:29
 Re: ford LGT 16 into dually in reply to joe legge, 07-20-2002 10:43:16
If you can get a pair of front wheel weights from a Farmall A or C they will fit just inside the very outer rim and then run the bolts thru both wheels and the weight. It holds them tight and adds some extra weight.
Steve
Brian G. NY
07-22-2002 11:01:17
 Re: Re: ford LGT 16 into dually in reply to Steve Johnson, 07-20-2002 21:15:29
Steve, I like your idea even better; I may get lucky and find a set of those weights someday or something similar.
Brian G. NY
07-20-2002 12:31:41
One of the neatest setups I ever saw was a piece of band iron about 2-1/2" wide made into a ring that fit just inside the lip on the outermost part of the rims. The guy then ran bolts thru the weight mounting holes and drew the two wheels together.
j legge
07-20-2002 13:29:49
 Re: Re: ford LGT 16 into dually in reply to Brian G. NY, 07-20-2002 12:31:41
Super idea! Thanks
