CAT 0 attachments
Bruce
07-20-2002 17:34:39
Does anyone know of a website or a dealer/manufacturer of Cat 0 implements? I am especially interested in tillers.....
Ryan
07-27-2002 22:27:24
 Re: CAT 0 attachments in reply to Bruce , 07-20-2002 17:34:39
Just had a 42" box blade and a 42" reversable blade made for a Sears Suburban electric 3-point. Camen offers several items I wanted for my tractor. I must pass on to you that these cat.0 impliments did not fit my cat. 0 3-point. It seems after a certain year the manufactures standardized the 3-point. Before this standardization, only the make tractor and impliment would work together. I can't say this with certanty but, from my experiance, this is what I'm seeing with my older Sears. Looking through catalogs that carry catagory 0 and 1 3-point equipment, the only difference is the size of the pins. The dimentions are the same. This is where I failed to research, the pins were 5/8 alright but the spacing was WAY off. Camen did offer to modify both blades and I sent them back and now everything is just fine. In fact with tractor lugs and wheel weights, pulling that box blade in high gear range in 3rd gear (top) with dirt spilling over the top the tractor pulls it just fine. People had told me it wouldn't pull that 42" blade. It doesn't have the scarfer (ms) tips. What I've been doing is leveling my yard, I have the 42" 8hp rototiller attatchment, I soften up the dirt first, switch to the box blade, back & forth. This yard doesn't have room for anything bigger then this garden tractor to move around. This is working so well, I couldn't ask for a better machine. I hope you have as great experiance with your project as I have had with mine.
'84 318
07-22-2002 21:48:03
www.befco.com has them new, in several widths. They are made in Italy, nice units, a little pricey, around $1700 from my local dealer.
ironhead
07-21-2002 06:44:28
the old farm and fleet and tractor supply stores did. dont even know if any of these stores are still around.
lewis field
07-22-2002 16:59:51
 Re: Re: CAT 0 attachments in reply to ironhead, 07-21-2002 06:44:28
might try looking in some of the trade papers . Ones in my area have cat 0 tillers many times.
rick
07-21-2002 20:59:27
The fleet and farm stores are still around. I haven't seen a cat 0 tiller new in years. You can get plows, cultivators and other ground engaging implements. You can also get adapters that will mount sleeve hitch implements to cat 0 3 point.
