8 hp briggs
charging
ralph
07-26-2002 10:30:24
I have a briggs 8 hp in a small case 108.
The motor runs nice but the charging system was disconnected.
2 wires comming from the motor, what goes were???
thanks in advance
fred
07-29-2002 14:54:31
 Re: 8 hp briggs - charging in reply to ralph, 07-26-2002 10:30:24
Hello Ralph, Look and see if you have a rectifier under the blower housing on the carb side. There should be 3 wires from the alternator connected to it. If you do you have a dual circuit system. The fuse holder (if you have one) is just that. It takes a 7 1/2 amp fuse. the rectifier changes the ac to dc. The one on my case 108 is bad. If yours is good you should get 12 volts dc or more off the red wire. The black wire is for the lights, look for ac on it. If you don't get the dc voltage I have the info on how to test the rectifier. Let me know.
Fred
Fred
07-27-2002 06:32:13
I have the same model case 108. On mine there is a device on the other side by the carb. It's an aluminum thing that I think is a rectifier. On mine it doesn't work. Read my message on the board (Odd piece in charging system)
Fred
MOWMAN
07-27-2002 05:21:47
the two wires at the connector comming from the mower* the black wire is for light and the red wire goes to the battery
ralph
07-28-2002 19:50:27
 Re: Re: 8 hp briggs - charging in reply to MOWMAN, 07-27-2002 05:21:47
thanks Mowman
Red and black wires coming from stator.
parts manual shows fusing, should i fuse this if so what amp?, which wire, red?
what would be the easiest way to trouble shoot the charging system? am I looking for a number of dc volts????
thanks again
MOWMAN
07-29-2002 14:08:59
 Re: Re: Re: 8 hp briggs - charging in reply to ralph, 07-28-2002 19:50:27
without knowing which charging system you have because b&s uses about 8 different ones. go to the library or a b&s dealer and look at his books they have a simple way to id and how to check test with a volt meter, some use dc amp dc volts etc.
