Re: Battery will not charge
Curt
07-28-2002 16:36:11
what does the wire that you are grounding do when you shut the motor off. if it dosent spark with the key on and the motor off, that is probably the wire that charges the battery. you will probably need a voltage regulator on it so you dont overcharge it.
