Cub Cadet 127 Hydro wan't back up after a cold start up.
Hugh Wooden
07-29-2002 11:07:32
I have a Cub Cadet 127 Hydrostatic trans. Tractor will not back up when engine is started cold (after 8-10 hr. rest). After the engine has run for a few minutes (1-3) it will back up and is good for the rest of the day. Any ideas as to what could be wrong? The filter and fluid have been changed.
KNUT
07-30-2002 06:17:54
 Re: Cub Cadet 127 Hydro wan't back up after a cold start up. in reply to Hugh Wooden, 07-29-2002 11:07:32
Usually bad pump gets slower as fluid gets warm??
Jim S.
07-30-2002 06:03:07
On top of the hydro are 2 valves that screw in...one runs forward, one reverse. Remove them and swap them. Now, if you have the same problem in forward you used to have in reverse, you know that valve is bad. They are available new, around $75-$80. I have had some luck soaking them in PB Blaster and letting them sit to get them unstuck.
MOWMAN
07-29-2002 14:03:22
pump is goig bad,
HWooden
07-29-2002 16:06:54
 Re: Re: Cub Cadet 127 Hydro wan't back up after a cold start up. in reply to MOWMAN, 07-29-2002 14:03:22
Why will it go forward as soon as I start it and move lever to forward. Just wan't back up.
MOWMAN
07-30-2002 05:04:35
 Re: Re: Re: Cub Cadet 127 Hydro wan't back up after a cold start up. in reply to HWooden, 07-29-2002 16:06:54
DIFDRENT PASSAGEGES IN PUMP USED
HWooden
07-30-2002 09:51:56
 Re: Re: Re: Re: Cub Cadet 127 Hydro wan't back up after a cold start up. in reply to MOWMAN, 07-30-2002 05:04:35
OK
Most pumps will work better when cold. I'll see if I can find a repair manual. Thanks.
