Cub Cadet 1320 Won't Start
Matt Patchett
07-29-2002 22:18:36
I left the key in the ignition and my next time out it would not turn over, not a sound. I replaced the battery and still nothing. Would should be my next step. Also the PTO does not disengage.
Glenn(WV)
07-30-2002 05:27:14
 Re: Cub Cadet 1320 Won't Start in reply to Matt Patchett, 07-29-2002 22:18:36
The fact that your PTO won't disengage is probably your problem. I believe there's an interlock which prevents the starter from cranking over the engine if the PTO is engaged ... solve your PTO problem, and I'll bet she'll crank right over.
Matt Patchett
07-30-2002 09:24:32
 Re: Re: Cub Cadet 1320 Won't Start in reply to Glenn(WV), 07-30-2002 05:27:14
But it started before even with the PTO engaged. Is there any way to bypass this to check for another problem.
Glenn(WV)
08-02-2002 06:15:46
 Re: Re: Re: Cub Cadet 1320 Won't Start in reply to Matt Patchett, 07-30-2002 09:24:32
It shouldn't have done that. Perhaps the interlock itself needs serviced. If you don't have the service manuals, call Cub Cadet at 1-800-800-7310 to order them.
