Case 446 tiller
shawn
07-31-2002 10:54:01
I have a case 446 tractor that I need a tiller for,I have access to a tiller model h-70. Will this tiller work? What brackets would I need to install it? Or if it won't fit which tiller would I need? My serial # is 9729065.
Max
07-31-2002 17:04:49
 Re: case 446 tiller in reply to shawn, 07-31-2002 10:54:01
What you will need is a Hydraulic PTO, Sleeve hitch or three point and sleeve hitch adapter, and front weights and bracket. I tried using mine the cheap way without the front weights and its just to hard to travel from point A to point B if there is a turn in between those two points. You'll also want to put weight in the rear tires for added traction, bar treads or chains not needed. During the past twenty years of ownership I've only got mine stuck once with the tiller and thats because the tractor sunk down to the frame where nothing would have helped it out. The tiller usually gets it unstuck for it can either push the tractor or pull, thus the reason for adding weights to the rear wheels. The rear tires hold 10 gallons of fluid each so you're looking at 70+ lbs per side depending on fluid.
