317 vibrating
Bob
08-06-2002 13:46:04
I have a 317 that recently has started to vibrate. It seems OK at some throttle/gear combinations. I can't see any broken or loose motor mounts. Any ideas?
KEN
08-10-2002 21:53:38
 Re: 317 vibrating in reply to Bob, 08-06-2002 13:46:04
Look at the drive shaft from engine to transmission.Probably has a ujoint freezing up are slack in it.Fixed mine with a new shaft as you can't buy just a joint.
Dave
08-10-2002 19:11:16
Bob - 317s do have a tendency to vibrate. I believe Deere came out with a kit years ago, with some rubber engine mounts. Don't know if it's still available or not. You might check with a local Deere dealer. May take several dealers, since some may not be aware or want to take the time to look. - Dave
lynn
08-07-2002 17:33:54
Bob..check the fan on the rear of the transmission and the drive shaft from the motor to the transmission..lynn
