Yep, you can go straight from the battery to the coil and see if she starts. I did have a situation with no start/no spark once on a 129 that drove me nuts. Intermittant. Turned out to be one lug on the back of the ignition switch was rusted through, just barely hanging onto the switch. Sometimes it worked, sometimes not. I couldn't tell a thing until I pulled the wire connector to check for corrosion and the lug came off with it. The machine had been outside for a number of years before I got it. BTW, the diagram I sent says there's a 10A fuse to the PTO clutch, and there's also a PTO clutch safety switch. Check those yet? Looks to me like either one could cause yer problems, or be part of them. Looks like the hourmeter connects in just before that 10A fuse. Uh, I also might point out in case you haven't looked at the wiring diagram that the charge indicator is in series between the battery and the ignition switch. Bad connections/bad meter, there ya go! I bought a cheap Dodge truck once cuz it popped and backfired and the guy thought the valves were shot, and it was a bad ammeter! How could the ammeter go bad? Sometimes, just tightening up the nuts on the posts to reattach a wire can do it, if the post itself moves in the case and disconnects inside. Try jumping the ammeter leads. Yeah, concidences happen...but I'd rather do things slow and methodical and find the cause than jump all over. The probability is, it happened from something that occurred when you worked on it. Good luck.
