Briggs keeps flooding !!!!! driving me nuts!!
ben
08-10-2002 13:37:04
have a toro with a briggs engine. rebuilt entire carb multiple times. it keeps flooding the engine and even the oil gets loaded with gas. thought i set float right (even replaced float) but it still floods. works a few times but then floods again. anyone have a siilar problem? ok thnx for any help
NICK
08-30-2002 14:59:15
 Re: briggs keeps flooding !!!!! driving me nuts!! in reply to ben, 08-10-2002 13:37:04
I SOLVED THIS FLOODING PROBLEM 25YEARS AGO.IT IS SIMPLE IF YOU CAN SEE FUEL LINE MAKE IT A LITTLE LONGER PUT A SHUT OFF VALVE IN THE LINE.WHEN YOU GET READY TO START MOWER ONLY OPEN VALVE ABOUT ONE HALF TURN.REMBER YOU ONLY NEED A SMALL AMOUNT OF FUEL TO RUN MOWER.YOU BE THE JUDGE ON HOW MUCH FUEL YOU NEED. I ALWAYS PARK MOWER SHUT VALVE AND LET IT KEEP RUNNING TILL MOTOR QUITS. THIS WAY THERE IS NO FUEL IN CARB.USE A 1/4'' WATER VALVE I HAVE HAD MINE IN LINE FOR 25 YEARS ..IT WORKS GREAT FOR ME DROP ME A NOTE I WILL HELP YOU ANY WAY I CAN BLESSINGS FROM FLORIDA..
Chris
08-13-2002 01:51:00
Does it have eletric fuel pump? If so that is the problem. If not take some emory cloth sand the ears that the float ride in should fix it if you have checked everything else.
Chris Brown
08-12-2002 16:25:08
point the wire clip on the needle toward the air filter side.Don't know what this does but kohler and tecumseh recomend it.worked on mine
BMartin
08-12-2002 05:14:46
Make sure the float doesn't have a hole in it. I had the same type of problem with a 11 h.p. Briggs and the float had a tiny hole in it. Replaced the float and it fix the problem.
ken
08-10-2002 21:34:12
Change needle and seat and make sure the vent in gas cap is open.
sirmowalot
08-10-2002 19:21:58
Did you replace the Needle and Seat? Our shop has had several of the 12 - 16hp briggs 3 - 4 years old come in doing the exact same thing. They run fine and when they set they flood so bad that they hydrolic lock the cylinder.
Glenn(WV)
08-10-2002 15:36:13
I realize that this doesn't solve the core problem, but it will prevent the flooding: add a fuel shutoff valve somewhere in the fuel line - common, easy fix.
I am wondering if your float is getting hung up on something in the float bowl, like on a piece of flashing or something.
68 Mag
08-10-2002 19:23:36
 Re: Re: briggs keeps flooding !!!!! driving me nuts!! in reply to Glenn(WV), 08-10-2002 15:36:13
Sounds to me like if you're getting gas in the oil you have another problem...perhaps a blown head gasket?
