Cub Cadet Overheating
Frank Brady
08-13-2002 05:39:25
Have a '68 IHCC (122) 10hp Kohler, that just recently overheats. Bad enough to pop the fuel shut-off valve apart and soak me with gas... could have been someone else writing this by now. Nothing is obvious (rat nest, fan blade, etc.) Gratefull for any advice, FB
Frank
08-13-2002 10:31:38
 Re: Cub Cadet Overheating in reply to Frank Brady, 08-13-2002 05:39:25
Hello Bob: Thank you very much for the tip. I never thought of that, yet I'm aware of that condition occuring in Model A's. I'll strip the carb down and go from there. Sincere best regards and good luck to you, FB
Bob
08-13-2002 07:55:22
I don't consider myself any kind of expert, so you may get different opinions from others - but the thought that pops into my head is that the carb has some dirt in it and it's causing the engine to run lean. An engine that is running lean will run hot until it melts a hole in the piston or ruins something else.
Good Luck!
