Case444 control valve
larry
08-15-2002 08:45:49
i need help on setting the two screws on the control valve after the pump i need to know how many turns in to go or how to set them thank inadvance guys
Max
08-16-2002 19:21:58
 Re: case444 control valve in reply to larry, 08-15-2002 08:45:49
If you are talking about the releif valves you will need to 'T' on a pressure gauge. The one near the travel spool is set at about 2300 psi and the lift is set at 750 psi. With the tiller attachment, I prefer to set the pressures at 2500 and 1000 respectively.
