1965 JD 110 Engine Swap
Kevin Smith
08-17-2002 20:23:18
I have a 1965 John Deere 110 with an 8hp engine. I was wondering if a 10 or even a 12hp kohler engine would fit right in?
why
08-20-2002 18:21:22
 Re: 1965 JD 110 Engine Swap in reply to Kevin Smith, 08-17-2002 20:23:18
dif oil pan that 8 hp is right power for 110 and will do a lot i can push snow 5' tall with mine i cant do much better with my 314 tim
Steve
08-20-2002 23:47:42
 Re: Re: 1965 JD 110 Engine Swap in reply to why, 08-20-2002 18:21:22
Yes. They will interchange. Check the pan before installing the bigger motor and trim tractor to fit the new pan. I don't remember if you can interchange the pans. Might check that.Check output shaft of new motor to ensure 8hp pulleys will fit.
