Cub 126 steering: repair,rebuild or replace?
Denny
08-21-2002 18:52:36
Steering was loose but manageable when I got the tractor this spring.Got real hard to steer real fast last time I mowed.Now it has about 1/4 turn of slop and will hardly move the wheels.I can hear it slipping just below the instrument panel.Top nut is tight.What am I looking at as far as parts/availability/price?
Thanks!
Jim S.
08-22-2002 06:16:55
 Re: Cub 126 steering: repair,rebuild or replace? in reply to Denny, 08-21-2002 18:52:36
You can go ahead and repair the steering gear assembly yourself...it's not rocket science. You ought to have a service manual, available from Cub Cadet at 1-800-800-7310. Then you can order all the parts you need from yer local dealer or Scott Madson at Madson Service, 920-773-2661. You'll have about $30 or so in parts, and it will be good as new. The one thing you may have trouble with is the large nut at the end of the steering box. I remove mine with the flat end of a crowbar, by attaching a Vice Grip to the bar and then inserting the end in the large slot of the nut, then turning it out. Good luck.
Dave
08-21-2002 19:08:27
Check with the sponsors of the IH Cub Cadet site. One or more of them will completely rebuild the steering gear assembly at a reasonable price- or you can order parts from them, too.
