123 cub bearings
jason
08-29-2002 09:42:54
Does anyone know the what the specs are on front wheel bearings? I know mine are not correct. {Width specific} And how many different bearings could there be? Thanks, Jason
Terry
08-29-2002 15:21:21
 Re: 123 cub bearings in reply to jason, 08-29-2002 09:42:54
ask here: Link
jason
08-29-2002 19:55:18
 Re: Re: 123 cub bearings in reply to Terry , 08-29-2002 15:21:21
No response there either, must be rocket science?
Thanks
Jim S.
08-30-2002 05:45:16
 Re: Re: Re: 123 cub bearings in reply to jason, 08-29-2002 19:55:18
I know you can still get the front wheel bearings from any Cub Cadet dealer, which is what I do. I never bothered with the specs, just buy the bearings. They are not outrageously expensive.
On some older rims, the bearing hole will egg out or wear out because someone ran worn-out bearings on it. You can stake new ones in with a punch, or I have seen guys use two dabs of JB Weld on the new bearing and then let it set up. If you ever have to replace it, just drive it out from the other side. But only two DABS, don't coat the whole outside of the race.
Hope it helps.
